If you own a big house and only want to have one vacuum cleaner to do it all, our team at TheKingLive.com typically recommends spending at least $250 to get a long-lasting model that does its job well for deep cleaning carpets and hardwood floors and can last through years of continuous use. That said, you can still get yourself the Best rated vacuum cleaners that are sold for $100 or less!
Would there be any disadvantages when it comes to cheap vacuum cleaners? Typically, a vacuum cleaner with a more affordable price often contains more plastic parts, and they can lack some of the upscale features, or they might not last as long as other models with a higher price. However, if you don’t want (or need!) your vacuum to be a super durable one, cheap vacuums can undoubtedly get the job done with flying colors. Therefore, if you’re a little low on budget yet need an extra hand keeping things around your house tidy, take a look at this list of five cheap vacuum cleaners!
1 - Bissell CleanView Bagless Vacuum
The bagless vacuum Bissell CleanView is a Good Housekeeping Seal holder and is equipped with five height settings that allow you to clean deep and low pile carpeting and everything in between. If users need to remove pet hair and lint from carpeted stairs, the turbo brush will work wonders. Also, the plastic dust cup empties from the bottom which will cause less mess than other styles. There is a 23-foot cord and a washable foam filter included when you purchase the vacuum. Weighing in at only 15 pounds, carrying it up and down stairs is pretty easy.
Find More Info: Best vacuum cleaners in the world
2 – Eureka Mighty Mite Bagged Canister Vacuum Cleaner
This mini-powerhouse has seated itself on the market for a long time, and there’s a reason for it – because it works! Being one of the most favored lightweight vacuum cleaners, this Eureka is a champ when it comes to bare floor cleaning. There’s a seven-piece attachment set designed for floor-to-ceiling cleaning and a HEPA filter to conceal allergens.
3 - Bestek Corded Stick Vacuum Cleaner
Who says only fancy vacuums can provide excellent results? With the Bestek corded stick vacuum cleaner, you can still rid your house of all the dirt, dust and allergens! The machine is lightweight, making it easy to vacuum on surfaces like flat rugs and bare floors. What makes it better is that it never runs out of power like other cordless models usually do. In case you need the convenience of a handheld vacuum, just remove the handle and nozzle.
4 - Bissell Lift-Off Floors & More Cordless Vacuum Cleaner
Looking for a low-cost yet multi-purpose vacuum cleaner that can work on almost any surface in your home? Then this Bissell is a perfect choice for you. Due to the design being cordless, you can move around the rooms of your house with no difficulty without being tethered to an outlet. This Bissell also has a rotating brush in case you need to clean the pile carpets more thoroughly, and there’s even a switch that turns off the brush to make sure no scattering and damage is done to bare floors.
5 - Bissell CleanView Deluxe Corded Hand Vacuum Cleaner
It may be unbelievable, but this little hand vacuum cleaner has non-stop power, and thanks to its 18-foot cord, you can clean hard surfaces, upholstery, stairs, and more. When dealing with pet hair and lint that clings to fabric and carpets, the flexible rubber nozzle of this design works efficiently. If you want to reach places such as the tops of bookcases and the crevices between car seats, pop on the two-foot hose and one of the included attachments.
Selected For You: https://www.flickr.com/groups/best-vacuum-cleaner/
Conclusion
There are many inexpensive vacuum cleaners for sale that can tidy up your living space pretty well! All you need is just more careful research, and you can still get a good vacuum even on a small budget.
